I have a 2003 150TXRB 2-stroke carb engine that I am looking to relocate the two batteries to the console from the bilge and reusing my Perko 1/2/all/off switch. It is my understanding that this engine has a built in lead for charging a house battery separately. I was told to connect the starting battery to switch terminal 1, house battery to switch terminal 2, and a lead from the rectifier / regulator to switch terminal 2. Accessories would also connect to terminal 2. The theory is that you run the engine with switch on battery 1, and the engine charges battery 1 through the main cable and the house battery through the rectifier lead. Is this correct?
What lead is it on the rectifier / regulator? There is a black lead with a ring lug, a red lead with a spade, red lead with a circular connector, and multiple wires on a circular connector. Do I need a second battery switch between the regulator and Perko switch? Do I need to fuse this leg; if so, what size?
