Picked up a used, but stored df15. Ran good after carbcleaning. About 5 fishingtrips. Then troubles began.
It became incredibly hard to start (Electric start, and auto-enricher)
Checked the mechanism of the autoenricher with 12v, it seems to be working OK, slowly pushes out about 4-5mm in 5 minutes.
I do not have a strobe-light to check ignition. But I looked at the timing belt and the cam-pulley against the timing-markings in the cylinder block.
It's hard to tell if it's good or not, but it's darn Close to the number 1 marking on the pulley while at top dead center.
I checked top dead center with basic digital calliper, and it aligned (within reson) to the marking.
Can the Suzuki service shop hook this df15 up to a diagnostic tool? And how does that diagnostic connector look? (cause I haven't found one on mine...)
I noticed that the timing belt does not have a "tensioner", but runs directly between crankshaft and camshaft, does that mean that even I could change it
as long as I align all markings and make sure they are as Close as humanly possible?
(No motor background but reasonably clever....)
All suggestions are welcome, especially video-links to DIY.
I have the workshop manual, from an web-page.
(sorry for whatever language-mistakes you find, I'm Swedish)
