Seacraft20
- Jun 1, 2015
- 1
Does anyone know how to test an ecu for the fuel pump output? I know that it works from switching the ground on and off. Here is my dilemma. Electric pump wasn't working. I checked voltage with meter and had 12.6 volts. Figured pump was bad and bought another. Same issue with the new pump. Nothing would happen. but if I checked the plug I had voltage. What I found out was the second there was a load put on that circuit it went to 0 volts. It shut right down. There arent any relays or fuses inline. The circuit goes directly to the ecu. I checked the ground for the ecu, even hooked the ground direct to the battery. Still nothing. Any help is greatly appreciated. The lowest price I can find on a new ECU is 1650.00.
