I recently purchased a 2001 Yamaha F50 (F50TLRZ) knowing I would need to put work into the lower unit (busted bearing carrier and bent prop shaft). I have removed the lower unit, water pump, driveshaft oil seal, prop, bearing carrier and shift rod. According to the manual the prop shaft should be free, however the bearing, thrust washer and reverse gear are still firmly in place. I headed the gear housing and tapped with a rubber mallet to help free it from the built up corrosion but the prop shaft will not break free. I feel I have followed the steps from my manual. Am I missing something?
