I went through step by step. Here is what I've done so far: New Water Pump Kit, New Popit Valves, New Thermostats, I took the head covers off thoroughly cleaned the entire water column of the engines with a salt de-solvent, Bought New Head Covers and Gaskets, Installed Temperature gauges in the heads, By Passed the Oil Alarm due to premix of oil (by a master yamaha tech), and I replaced one Temp Sending Alarm Plug and tested all the rest in hot water to make sure they worked properly. I don't know what else to do. The alarm goes off soo easily sometimes. Some days I can run for 20 minutes with no alarm and some days I can't get out on plane without it going off. The water temp here is 57 degrees in the ocean. It is a steady alarm that triggers both motors to limit rpm then I go into neutral and it goes right away. The only thing I have'nt done yet is trace the pink and I think brown wires from the senders? Where are they supposed to go? I just am frustrated with this and any help would work.
