After changing impellor and reassembling the forward and reverse gears do not select like before. Reverse seems ok but the engine starts revving before forward gear engages then engages suddenly. How do I correctly adjust the linkageso both gears engage correctly. I know is something to do with the linkage connector nut above the lower leg as I undid that to fit the new impellor
