Hi guys...
'89 DT15 Suzuki. Just put a new prop on it with smaller pitch. Don't know what was on it, but I believe it was OEM which was 9. The new prop was had a pitch of 7.
I also just put fuel in it on the way to the lake.
Once on the water, I started her up and she ran just fine like she always had. I noticed it was running higher RPM's which was expected due to the smaller pitch prop. I went to see what she would do at WOT and after about 5 seconds she shut off. When I tried to get her started, the rope was very hard to pull at first. After trying a few times, I loosened the rope up...but once it started...as soon as I put it in gear...she died.
After that, I couldn't get it started.
So I have her home now, and the first place I came to was here. Fixing to go check her out...what do you guys think? Did I blow the motor? Do you think it's bad gas?
Thanks.
Thanks.
