Corby:
Based on these 2 posts in the old topic you posted in:
And combined it w/ your other 2 topics about this motor:
Topic1: I recently purchased a Spirit 5hp. With some research I've learned it is a 1978. I'm having a problem getting spark. Narrowed it to the coils. I think. Wondering if anyone knew the specs on testing these coils? From where I've looked, you can't get these coils anymore. Is there a replacement?
Topic2: I recently --- [duplicate text redacted] --- a replacement?
Re: Spirit 5HP
Their advertizing claim is that most of their parts are the same as Yamaha. I guess now you will find out if that is true or not.
I moved your post in that topic:Re: Spirit 5HP
It's an old Suzuki.
I've had a couple/few with weak (electronic) ignitions that I was able to continue to use for years without issue just by reducing the plug gap to .016-.018in.
It's been a few years since you started this thread. Did you find the specs for testing the coils, and did you find coils for it? I'm having the same problem.
Edit: Please try to avoid posting in 90+day inactive topics and avoid starting multiple topics across multiple forums about the same subject. Here in Yam/Suz sounds like the right place based on the 2 quoted posts above.
Thanks
John
Thanks
John
