I have a suzuki dt150 ss (96 i think) with an alarm issue. Upon starting i get a intermittent beep that has maybe a 3 to 5 second pause between beeps. The gauge shows 2 of the 3 vertical green lights lit up. I dont know what these indicate exactly but all 3 used to light up while it was running. Also there is a water symbol to the left of that that lights up. There is a steady stream coming from the tell tale and i have not noticed the engine getting hot however i have not run it for to long at a time since this started happening. Ive checked both water sensors and as far as i can tell the were in working order. Ive pulled both t-stats and did the pot test. Both opened altho one was a tad slower at opening. Is that the culprit or should i be looking at something else?
