They all should be within 10% of eachother. The actual number can vary greatly depending on what type of battery is used, the condition of the starter and battery cables so its hard to give a solid number on what they should be that's why you mainly look at the difference.
Make sure the throttle plates are open when doing compression test, its very important on a 4 stroke.
