Hi everyone,
so I'm looking at repowering my ssv151 with a smaller ob as on the rivers i can't use the power.
For economy cost and reliaility i am looking at 80s/90s yamaha 55/60 2 cylinder.
Firstly is there much difference performance wise?
secimndly i can only find 3 and each as a problem and i am trying to work out if they are write off or worth buying to fix...
firstly I've found one 55 and one 60 with the same problem... only sparking on one cylinder... both owners say they have tried swapping he coil and not the issue and there is good compression.. is this common and expensive to fix?
the other is a 55 and runs fine when going but it costs out when idling... any ideas on a problem like this?
apologies for vagueness ... cheers
