Knot Stressed Charters
- Jan 18, 2015
- 3
I have a 115hp 4stroke I am having an issue with the oil pressure alarm sounding. I have checked the oil pressure reads 49psi. I can start motor the alarm will sound, I turn the motor off and start back up alarm will sound. I do this several times allowing the motor to warm up and it will stop and not do it again all day unless I set for a long period of time and the engine gets cold again .This does not happen in the summer time at all. I have undone the oil sensor from the ground, I think alarm should stop sounding, and the alarm continues. My thought is the sensor is bad, does anyone have any other test I should complete before replacing the sensor
