Hoping to get some help...I am repairing a boat for my best friend that is going through his third round of Cancer treatment. Engine had sat for 5 yrs, rings stuck...I have overhauled engine with all new internals but I went to start, no ignition with a visual spark checker. Here is what I have done so far:
-disconnected whit wire to CDI to eliminate the kill system...still no spark
-All wires/harnesses/ground have been checked at least 10 times...
-Took ohm meter and checked trigger/pulse coils...they are not shorted to ground and the ohms are within limits perfectly....
This is where it gets better...
-When I check the stator wires the brown to blue, which according to specs should read 840-1260 ohms actually reads OPEN, with a digital multimeter, and with leads disconnected from the CDI.
-When I check the Blue to Red, specs call for 65-130 ohms but again, I get OPEN.
I do have a Oil System emergency switch ordered as the pump will not shut off, overfilling the tank and all the floats test good so
