Seadoomanls
- May 12, 2007
- 83
I have a 1994 Yamaha 115 V4 outboard that has ran flawlessly since I purchased it back in May 2013. About two months ago, I let the boat sit for 4-6 weeks. Before this, the boat was used at least once every week. When I went to use the boat, the motor fired up just fine, so I took it to the boat ramp and launched the boat. The boat is oil injected, and for the first time had a lot if visible white smoke. The boat idled and got on plane to my favorite hole for bait. I shut the motor down,caught my bait, then the problems started. The boat had a tough time idling and did not get back on plane.
Brought the boat home, changed all the fuel lines and fuel ball, water/fuel separator, cleaned and rebuilt the carbs, added 8 gallons of fresh gas to tank and tested the boat. Boat idled fine and I idled out to a lake for a test run... Ran good. On the way back in (about 20 min run time total) the boat stalled and had a rough time idling back to the dock.
I let the boat sit out of frustration and attempted to use it again yesterday. The boat will idle on muffs no problem. When I put the boat in the water, the boat will idle WITHOUT the cowling. Once I put the cowling on, the engine begins to sputter and dies out. This happens no matter how high i set the idle. Has anyone else had this problem? Also, when I added new gas, the old gas backsplashed out of the tank a little bit and was bright yellow...
I guess my main question is, has anybody had the same change of behavior from removing the cowling?
