Paul Zarpaylic
- Nov 24, 2014
- 6
90 HP 2008 Suzuki outboard. Buzzer and light came on for overheat out fishing. Took boat home changed thermstat dropped lower unit and put in new impeller. Cranked up motor and have great flow from tell tale pee hole (motor in a tub no muffs). Took two temp sensors out and checked them with OHM meter and seem to be working. Manual says the (EM) exhaust manifold sensor might be bad and causing the light to stay on. Anyone have this problem or experience please advise. Paul Zarpaylic Melbourne, Fl.
