MSGTUSMC89
- Dec 21, 2014
- 2
Up until today I have never had an issue with this motor. It fired right up when I backed it off the trailer and idled fine for about 5 minutes then died. I tried for almost an hour to try to start it. Every once in a while it would fire off but would not run for more than a few seconds. We were in a tournament so my partner and I started fishing. A couple of hours later I tried it again and it fired up, I got it on plane and it ran for a few minutes then cut out and died. It would then fire off and run for a couple of minutes then die. I tried it again an hour later and it did the same thing. As the day progressed it seemed to run a little longer before it died. We noticed that if it died if we pumped the ball it would fire right off. The ball was hard but for whatever reason it seemed to help.
I have had the motor since it was new, it is garage kept, I change filters and plugs every year. Before today it had not been ran since August.
Any help would be GREATLY appreciated!
