I have a '89 Yam 90hp with a tilt problem.
It will trim up without any problem,until it reaches the end of the trim rams,then it stops.
The main tilt ram doesn't seem to be filling with hydraulic fluid.
I've taken the PTT unit out and put it in a vice and I can get it to tilt right up,but I can push the main ram back down by hand.
I've got a manual but it doesn't shot the ptt internals very clearly.
I'm wondering if the problem could be in the shock absorber valve or check valve in the main tilt cylinder?
Any ideas?
Any ideas?
