lstewartff
- Mar 6, 2013
- 53
I have a 1990 Yamaha 115. the last time it was out it only started part of the time. I tried to start it in the yard the other day and it would not do anything. I used the tilt/trim for a minute then it stopped working. Now when I try to turn it over or use the trim I has a clicking sound coming from the relay assembly. I noticed that there is 2 relays in this box and the bottom one is the one making the noise not sure what the top goes to. is this relay out or can something else be causing it to do this. The whole assembly is expensive so if it could be something else I would rather replace that instead. Thanks for any help.
