The Right cylinder bank is not warming up. I let it run on the flusher for 15 mins. I swapped t-stats from the other bank and no difference. I removed both t-stats and cover and do see water is coming up to the t-stat. Could there be an issue with my Head gasket? Anyone have a water flow diagram?
I removed the Poppet valve and spring. I did not see any thing holding that open. all seems clear there.
