Hit a stump! 1995 Yamaha F9.9 MSHT
rebelblue
On my way back in last night, I was in an area of the lake I'm unfamiliar with and found myself too close to shore. Hit a submerged stump at nearly full throttle before I could veer into deeper water. Powerhead is seemingly fine, but the prop will not engage when put in gear. I took the motor off the boat today and laid it down. I removed the prop hoping it was a shear pin, but now I know this motor does not have one (splined shaft). I could spin the prop in forward and could feel/hear gears turning inside. However, I could not shift it into reverse-- the shift lever just refused to go backward.
At this point, I'm planning to take off the lower unit to see what's bent/broken/etc. A few questions:
1. Any guesses on what the problem might be and/or what I ought to be looking for?
2. Any words of caution or other "hey, watch out for X" specifically pertaining to the lower unit removal of this outboard?
3. While I have the thing disassembled, what maintenance should I get done in addition to (hopefully) fixing the original problem?
Thanks so much for taking the time to read my post and offer any suggestions.
Cheers.
Bifflefan
So I guess its ridiculous to ask why you were going "nearly full throttle, in the dark", at all, let alone in a place you don't know.
As to your questions, get a book before you start or let a pro look at it. While I don't know Yamaha, I can only guess there are things that need special tools to put it back together.
rebelblue
While letting a pro look at it would ensure I wouldn't have to worry about any of my questions, I don't see it providing much in the way of learning something about the motor. I may well need to take it to a pro and I certainly will if I can't fix it myself, but that's plan B.
A book would be nice indeed. Do you have any suggestions? I've found the parts list manual with exploded diagrams of everything as well as the owner's manual, which is not a very big help.
Ridiculous to ask why? I suppose not. Helpful to ask why? Not really, but thanks for the smack upside the head. Now I just might not do it again.
Any pictures ??----Any damage to the front of the gearcase ?-----Any damage to the prop ?------Have you checked gearcase oil ?
rebelblue
No damage to the gearcase and no damage to the prop. Gearcase oil is still in there and there aren't any leaks. Here's a pic that shows as much. I just built the motor stand during my son's nap time. I probably won't get to removing the lower unit for several days so I'm gathering as much info as I can in the mean time.
If there is no damage then maybe you did not hit anything.----Maybe something broke in the gearcase and it locked up.----Makes you think you hit something.--------Drain the oil for a " look see "
rebelblue
I'll drain the oil and take a look for sure, but I know I hit something. The strike not only jarred me forward, but it also muscled through the manual tilt release lock/lever and the motor to tilted up out of the water and pointed the prop at the stars. I had to push it back down.
rebelblue
Got it apart and found a sheared drive shaft at the pinion gear. Thanks for the thread views and replies.
rowboater
Just curious how can you shear a driveshaft and have no damage to the prop ? Seems next to impossible a lower unit could flex that much.Unfortunately I have hit many things over the years that have bent props,sheared pins and spun hubs but never sheared a driveshaft.
rebelblue
I hear ya, @rowboater. Here's a shot of the prop. It's not the prettiest in the world, but it looks no worse after the hit than it did before it.
rowboater
Thats really something it even looks to have a rubber hub.Learn something new everyday.Thanks for posting the picks and good luck in repairing it.
