1999 Yamaha OX66 oil leak
w987rl1
I have found oil inside the transom area after the engine was in the tilt position. Also that same engine burns or leaks much more than the other identical motor. I found that by looking at the remote oil tank. I did see a trace of oil in the water yesterday after a cold start. Any suggestions any one would be appreciated ?
99yam40
do not keep posting the same thing over and over.
You can post on your thread and it will bring it back up to the top If that is what you are trying to do
Try to delete your other threads and just leave one.
If some one has any info for you they will post it on your one thread
jerryjerry05
The hoses might need a clamp or the tank is cracked, or the pump linkage is out.
Take it to someone who can adjust the linkage right.
