lake tahoe
- Sep 14, 2014
- 4
I have a 1989 suzuki dt65 3 cylinder oil injection outboard. Problem is when in gear in water it will rev up to about 2000 ish rpm and then die off and stall. The carbs have been dismantled and cleaned and the air screws set again to standard, the fuel pump was by passed with an electric version which made no difference. All 3 plugs are sparking ok. When engine is running, if I remove either no2 or no3 plug lead the motor still runs and sounds the same??? If I remove plug lead no 1 it dies. Also carb 1 has a loud suction sound, whereas carbs 2 and 3 are a lot quieter. What do you deduce from this?? is the crankcase seal leaking around 2 and 3 cylinder perhaps or am I missing something obvious??? Also the control dial with leds and buzzer does not and has never worked.
