I'm a bit stumped with this one, engine was running without any issues after it was started. Starting was a bit of a challenge, had to have another person pull the choke in and out on the motor while starting. After the motor was hot and running would start with no issues.
About 2 weeks ago the engine started acting up, when on the water running at about 2-3k rpm, after giving more throttle, it would stay at same rpm's then it would kick up the rpm's about 20 seconds later.
I pulled the plugs and lower port cylinder plug had oil build up all over it(all other 5 plugs looked good). I pulled the head and there was about 1/8" of oil buildup in that cylinder head.
This boat has 2 engines and this engine has been using about 30% more oil then the other.
Any ideas on what could be causing this?
Thanks in advance for any help
Alex
Alex
