Hi, I have a 2003 SX150 that after running for some time, the oil tank overflows into the air silencer and begins to smoke. The oil sender in the upper and lower tank has been changed, and we've tried another CDI unit. The blue/white wire going to the sender has continuity. It usually takes about 1-1/2 to 2 hrs to begin to smoke. Where should we go from here? Any suggestions?
Thanks in advance!
Thanks in advance!
