I have a 1988 Seaswirl with a 52 gallon built in fuel tank. I am running an OMC 5.7 Litre engine. I want to hook my outboard to the main fuel tank vice using the little red 3-5 gallon plastic tanks. Is that possible?
It will not run long on straight gas if it is a 2 stroke.
If 4 stroke then make sure to put shut off valves inline so you do not suck air from the other motor while pulling a suction on same line if that is what you are going for
