I am running this as a 2 cycle. Great comp., runs like a champ up to 1/2 throttle and then stubbles/vibrates and will not gain any RPM's over 1/2 throttle. My question, I am guessing the ICM is confused and is going into "safe" (limp) mode for protection. Can I loop the oil tank leads or oil flow sensor to trick the ICM ? when I inherited this boat, the tank and what ever else had been removed and just trying to get it going until $$$ for newer power. Thank you in advance, Repo
