I have a 1999 Yamaha F50 four-stroke. After I start it up and run it for a minute or so, water appears to be coming out from around the engine oil (not the gear oil) plug. Is this normal, or do I have a problem?
I'd be checking your oil level and see if its in the engine first off, if not then it could be leaking from inside your cowling and down to where your drain plug is...Sherm
