Suzuki DT 30 CDI problem
Scuba08
Hello
i have a problem on my Suzuki DT30 not started .i found that ther CDI is not working i have power in but no power coming from it.i checked the Ohms there is nothing.the problem that i am not finding that specefic model is there any compatibility to use any other CDI box on that motor
99yam40
Model and serial numbers will help identify your motor, so post them.
Did you use a proper peak reading voltmeter to take readings into and out of the CDI?
Scuba08
yes of course as well i have removed the plastic cover and found a little explosion a cirle one on the left side this is to make sure that it is deffective .the problem that i am not able to find from that model ,do you have any idea what should be the output voltage from this CDI maybe i can use any motorcycle model as there is many for motorcycles but with different outputs so i am not sure which one i should try ,any idea ? the model number DT30 model 1984 but serial number where i can find
