Need help troubleshooting. I have twin 1998 Suzuki DT 200 outboards. This problem started while running 25 kts. At motor started to over heat so I shut off. After it cooled it wouldn't restart. I pulled the cowling and noticed I the starter was smoking (I know better than to let the smoke out). Got home ordered a new starter and water pumps. Replaced both starter and water pump but the motor still won't start. Since batteries are getting older 3 yrs. I replaced both batteries. Port engine is fine. Starboard motor still won't start and starter is barely turning over like loss of voltage. Before cranking I have 13+ volts at solinoid and while cranking it drops. Next I replace the battery wires from outboard to battery switch and from battery switch to batteries. Still won't start. Checked for spark and no spark. What next? Any advice?
