Re: 1996 Yamaha 225TXRU Engine Alarm
You added oil I presume to the boat tank. That tank and its sensor have nothing to do with a low oil alarm.
Remove the cowl and inspect the engine tank. Is it full or not?
If you have a Yam tachometer what do the lights or lcds look like?
Can you transfer oil using the over ride switch?
Keep driving with the low oil alarm activated and the buzzer sound will be the least of your problems.
