I have a new Yamaha F115 on a new Smoker Craft Phantom 202. The motor runs great but I am having trouble getting used to the throttle control and was hoping there is an adjustment that can help.
The issue is that when I put the motor into gear in forward or reverse, I have to move the lever a loooooong ways before the throttle begins to actually increase. I have to move the lever almost all the way forward or back before the motor starts to speed up. At that point, there is very little travel distance from idle to full throttle. This makes for some difficulty in fine control of the throttle.
Its especially troubling when docking and you need to go quickly from forward to reverse and back.
Can this be changed by some adjustment in the control box or at the motor?
The control box is a very simple single lever with just trim/tilt - no gauges or anything else on it.
Thanks!
Larry
Thanks!
Larry
