mike kelleher
- May 7, 2014
- 3
Excuse me in advance for a lengthy post. 99DT140 suzuki. After installing a knwn good ecm I am experiencing an alarm issue. 15 seconds after start I get a single alarm tone and the engine may or may not go to limp mode. I have replaced the impeller, tested t-stat and temp sensor and I know it is pumping water[pours from t-stat hsng if open]. The alarm is showing a red temp icon and red light under rev. If I continue to run the engine will run and about every 30/45 sec the alarm will go off[1 beep may/may not go to limp]. Water from the stream is warm to the touch but not hot. I also tested the oil level switch and it is working and I drained and cleaned the oil tank an lines but I have no idea how to check the flow sensor. I believe it is getting oil as I see smoke and I have run it for some time. I am lost as what to do or ow to proceed. Any suggestions would be very much appreciated, thanx
