Hi Everyone...Just picked up this 1999 Yamaha Enduro 75 hp motor....Put it on the stand and it fires right up but it's not peeing....Going to pull the lower and replace the water pump..
Question: (1) Do I need to disconnect anything on the shift rod under the carbs?...
(2) Iv'e also seen posts about disconnecting the speedometer.....which I'm not sure that applies to an Enduro as I don't see one.
(3) Any advise or tips ...Iv'e changed water pumps on Mercruisers merc outboards and evinrudes in the past...first Yamaha
