Just launched the boat for the first time in a year and a half, and it wouldn't back off trailer when put in reverse. However, it could shift into forward and I could see the thrust.
After shifting back and forth, it still would not shift into reverse even though the linkage inside the cowling appeared to be moving like it should when gear lever was shifted. Now it seems to be stuck in forward.
Any (hopefully easy) suggestions? I'm afraid it means pulling the lower unit off.
