*DT200 Prop issue...
Hey guys, just wondering if my prop has problem, the motor didnt run right today and it couldnt go much faster than idle without the motor revving up very fast . It felt like the shaft was spinning inside of the prop above idle. Think its the prop?, if so what pitch do you think it would be? Thanks. To my knowledge it is a stock prop, but it is stainless and i dont know if stainless is even stock.*
Is there a Propeller's hardware kit comes for it? Such as Bosch or Seal or the reason could be something else?
Thanka ,
Thanka ,
