Hello, got afew troubleshooting questions.
2001 Yamaha (150TXRZ) with multifuction speedo and tach guages.
Got the boat about 6 months ago. Motor runs fine and I knew the prior owner and boat history. The gauges never worked since the day I got it. There appears to be a slight haze on the inside of the glass (moisture?). I did some trouble shooting today and found a blown fuse... when I replaced I was able to get a VERY DIM readout. I assume the gauge is bad. Is there a fix for this? Or just swap them?
Also, out of the dimness, the gas "bar" portion was darker, but it flashed on 1 bar only. Not sure if this means anything, other than low gas. I checked resistance at the sender and checked fine.
I checked all the wires for each and checked power/ground at the backside of the gauge. Everything seems okay.
Let me know if I missed anything. I wanted to get some insights before I dumped $100+ on each gauge.
Thanks,
Thanks,
