going tomorrow to look at a boat with a 115hp yamaha two stroke.
its a C115TL engine.
what should the compression be on this engine? was there originally oil injection on this engine? owners says he pre-mixes the oil so I'm wondering if oil injection is bypassed or not.
any other issues I should focus on looking at with this engine that could be bad? water pump pee, etc
I'm obviously going to test drive the boat if the compression is good and it runs good. So I know I'll check the gear drive for grinding going from forward/reverse etc.
what should it idle at?
