jughead028
- Feb 1, 2014
- 4
Hi All,
I jhave just bought a Suzuki DT30 - 1986 model.
The motor is set-up for forward control, but didn't come with the forward controls.
There are seven wires in the connector to the forward controls.
They are
White
Blue
Black
Brown
Green
Orange
Yellow
When the motor is connected to the battery, none of these wires has more than 1 volt.
From what I know of engines, one should be a "Live" wire - with 12 volts.
Another should go to the engine, and a third should go to the starter.
So if I connect the engine wire to the live wire, then tap the starter wire to the live wire, the motor should start (basic hot-wiring)!
How do I do this?
And what are the other wires for?
Cheers,
JG
They are
White
Blue
Black
Brown
Green
Orange
Yellow
How do I do this?
Cheers,
JG
