duskur1981
- May 3, 2009
- 8
I started having this problem two summers ago. It started out just once in a while. The motor will run perfect in neutral, even when you rev up the throttle, but once it is in gear it has no power and bogs down under a load. It used to run awesome on the open water then it slowly would bog down here and there. Usually if I revved it up in neutral and popped it into gear, it would kick out of the bog mode, and take off like a bandit. That doesn't work anymore.
I am convinced that it has something to do with the card jets, but I took it apart last summer, and it still acted the same. Although I am not sure if I got all the jets out because I wasn't able to remove the float.
I have tried different gas cans, and lines as well. I am at a loss, and want to get this fixed before Spring rolls around and I am dying to get back on the water. I have been having troubles finding info online about this motor, this problem, how to rebuild this carb or remove the float, etc.
I appreciate any future help. Thanks.
