Today at 8:16 AM
I have a Suzuki 2008 DF115 with cooling problems. I had all the routine things done to it, new water pump kit, checked water pressure valve even changed rubber exhaust seal below the water pump. I'm getting water coming out the thermostat housing but the water return hose coming off the thermostat has what feels like exhaust back pressure keeping the water from circulating. When you pull the hose off the thermostat housing you can feel the back pressure. We also tried blowing air back into the water system too. Now my mechanic tells me the next step is to pull the engine and check for corrosion or blockage in the water system. I'm trying to avoid the extra cost. I have taken it to my local Suzuki dealer three times to no avail, it just keeps costing me money! I have called Suzuki and they are no help whatsoever.
