Re: 2006 Yamaha 2 stroke revs up in idle.
i have a 96' 2 stroke merc, 30hp oil injected, practically a new motor (hardly used), same problem. runs perfectly smooth warming up, kicks butt across the lake, etc... its only when I come out of gear/ high speeds and into neutral, it'll idle down as it should, then it revs up about 1000 rpm for 5-20 seconds and returns to smooth idle... weird. dismantled the carb tonight, everything looks REALLY clean, will spray down and put new gaskets tomorrow, etc... if that doesn't do the trick, will continue the process of elimination. stay tuned...
Update: cleaned the carb & fuel filter. was hardly dirty at all, the guts were practically new inside. reassembled. everything seems to run very good in the yard. will put on water tomorrow for load test. stay tuned...
