Re: 08 Yamaha 9.9 4 stroke electric start charging
He says High Thrust in his original post so it has to be a T9.9ELH.
Mr. OP - You say that it did not come with any battery hook up cables. How in the heck are you starting the motor? Are you removing the engine cover and flywheel cover and using a pull cord each time you want to start it?
According to the parts book the motor should have had a set of battery cables included with it that would normally attach to your battery. Current flows from the battery to the motor for start up. Current then flows from the engine generator back down those same cables to recharge the battery.
Once you get a set of battery cables measure the battery voltage before start up. A fully charged battery will read more or less 12.7 volts. Then, start the motor. Recheck the battery voltage after a minute or so. You should see 14.5 volts or so, indicating that the charger is doing its job.
