livetoflsh
- Dec 18, 2013
- 1
I have removed both the head and water cover jacket and had bolt holes helicoiled
I bought 3 gaskets the head gasket / water cover gasket / power head gasket (as I needed to remove to get the heli coils done)
Genuine Yamaha Outboard 3 Cylinder Head Gasket 60HP 60 70 70HP 6H3 11181 | eBay
I plan on using gasket sealant on the water cover jacket and power head gasket and not on the head gasket (is this correct as I believe the gasket has sealant in it).
what type sealant should I use on the other 2 gaskets?
Thank you
Thank you
