sparkiedent
- May 13, 2011
- 5
I have a 2005 Yamaha F90C on a 17' key west center console on a lift.
It has been running great, but a couple of weeks ago, when I started her up there was white smoke coming out of the back. I shut it off right away. Then tried again, and there was some smoke, but then the water came out of the pilot hole, the smoking stopped and the engine ran really well.
I took the boat out and there was no problem at any speed. After the last run, I had raised the engine, so thought perhaps that was the cause of the smoking.
The other day I tried to start her up and there was a little smoke, but the water did not come out of the pilot hole right away, and after about 15 -20 seconds I shut her off as I know I risk damaging the engine. (The engine sounded good for this short time.)
The weather has been a lot colder, and the water is colder than I have run the boat in the past if that makes a difference. There was some ice on the deck of the boat when I started working on her that morning.
The Questions:
How long can I keep the engine running without water coming out the pilot hole?
If I use the flush port and water comes out the pilot hole, then does that mean the water pump is bad?
I may have sucked up some sand/muck earlier in the summer, but did flush the engine after that.
Is there anything else I can check while she is on the lift?
Can you run a hose thru the flush attachment with the engine running in the water to try and shake things up? or will that just make things worse?
If I can't get water to run out the pilot hole, then I need to have the boat towed to the ramp don't I?
Thanks for any advice you can give.
The Questions:
