sflman33176
- Nov 16, 2013
- 4
I have to say I may have screwed the pooch on this do it yourself job. I screwed the pump into the top overflow and left the bottom drain screw in needless to say after pumping away I noticed my blunder and had oil spewing from almost all the places it shouldn't. My question is what damage have I done to the lower unit and secondly how hard are the seals to change that I obviously damaged one of which was already going bad from the oil residue I found at the base of the propeller shaft. I already know I need a spanner wrench to get to the lower seal is this something I could attempt.
