This is my first Yahama, and I would like to find out what is needed to winterize
my outboard. I looked under the cover and there seems to be a connection to
attach a can of fogging spray. Is this correct?
And what other work should be done. Thanks
I'm sorry, hopefully this will clear it up. It is a 2003 Yahama 200hp-2 stroke outboard, fuel injected.
If you need the model number, I will have it over the weekend. Thanks again.
Definitely fuel stabilizer run through the system, I used to fog my carborated two stroke and I do know on the fuel injected snowmobile motors they have a built in "fog" button to do the same....Sherm
Hi, I have a question that hopefully you can help. My 2003-200 hp Yamaha 2 stroke has been stalling out at high speed first then at lower speed. It starts up right after with no problem. It seems that the gas supply is being cut off. Would you have any suggestions. Thanks
