Hello I have been told that the way to test a fuel pump on a 99 Yamaha 150 is take it loose from the block put your finger over the hole on the back and pump the primer bulb if gas comes out the hole its bad I have two pumps one has gas that comes out the other dose not,common sense says I have one bad pump but I didnt want to spend the money on one until I verified that this is how you test them
Thank you very much
Thank you very much
