Century Bay
- Oct 29, 2013
- 3
Reservoir pump will not come on.....Motor and tank were both purchased used from separate sellers....I have tried the following things:
Pump will not run automatic or from the switch on the motor (key on)
I have 12V between the connector plug (at the tank) and battery negative.....but negative is not showing up at the connector. Voltage is there at all times the key is on....but no negative in the connector
Pump will run if I apply pos and neg from the battery, direct to terminals in the connector plug.
I have checked continuity in the wiring between the motor and tank, all is good.
Question: 1) is there a relay somewhere that controls the negative wire from the float and remote switch?
2) if the previous owner of this motor disconnected the oil system, and ran it premixed, where is the disconnect commonly done
