I have an '85 DT30 I've been working on for a while. Customer brought it in because it would crank and crank but not start. The only way I could get any spark out of it at all was to flick the key switch back to the off position, then to the run position while the engine is still turning. Confusing, I know. I have checked every electrical system, double checked my grounds, tested continuity on the kill wire, everything.
I had a few calls into the Suzuki dealer, he said to test it with a different key switch. Didn't change a thing. I had a CDI lying round and swapped that out, still no change.
I am wondering if anyone has had a similar problem to this at all. This is perhaps the weirdest problem I have run into.
