Ok I'll try to make this short...my old yamaha outboard has no spark used a spark tester no spark to any coil. Disconnected white kill switch wires at cdi jumped the motor still no spark. So here's my question I want to check stator and pulse coil trigger in the order someone tells me to start. I got a multimeter and dva adapter, will a generic multimeter work my adapter fits right in i bought online. What settings do I set meter at is it dc volt or dc amps? What do I check first where do I put my wire leads to which wires and what should I be getting as a reading to start eliminating what my electrical issue is. thanks everybody. Appreciate the patience I can follow directions but never tested outboard electrical beyond battery voltage.
